Comprehensive information, Nyogtha. While I respect your qualifications, the contention with this issue is more rooted in language, and I think you said it best.
Originally Posted By: Nyogtha
includes hydroisomerization (catalytic dewaxing) in its processing steps
'Synthetic' suggests to me that a product is synthesized from directly unrelated compounds- taking two chemical feedstocks and producing an entirely different product- hydrocarbon oil.
Example, the Fisher-Tropsch process I would call true chemical synthesis, as the feedstocks are simple gas compounds reacted on catalysts to produce uniform viscous (often solid) hydrocarbons. Esterification is synthesis, because neither alcohol or acid chemical feedstocks are considered a 'hydrocarbon oil' but their reaction produces exactly that. Same logic applied to PAO, polysiloxanes, alkene glycols etc.
OTOH When it comes to GrII/III, it's just processing and refining IMO, not synthesis. The feedstock goes in as hydrocarbon oil and exits the process as hydrocarbon oil. It goes from being a dirty hydrocarbon oil mixture, having undesirable visco properties and irregular chain molecules to 'clean' hydrocarbon base oil with more molecular uniformity and sought after desirable properties. At no point does the oil change to something other than what it started out as- HCs. It was always HC, just now tailor processed to chains/structures you like, saturated with H and sequestered clean. Yes, catalytic and chemical reactions occur, no doubt about it, but it was always oil. Wouldn't consider GrII/III any more synthetic than margarine.
I'm clearly not a chemist by trade, so I need to ask if you agree or not. Am I misrepresenting anything about the hydro-cracking/isomerization process? Basically, how wrong am I in my apprehension to appropriate the word 'synthetic' to GrII/III base stocks?
Cheers
Cheers
