No idea how long it had been installed but it was really not in bad shape. The seals were for sure the worst part.
I worked pretty hard on this today. I forgot to order one part, a seal retainer for the balancer shaft seal. It was a recall; the seal had a tendency to blow out and cause lost oil pressure. The recall campaign ended in 2003, but the part is still available. Luckily the Honda dealer was able to overnight it for me. It was $4.
Got everything for the timing set together, new seals, belts, and tensioners on. Getting the lower cover back on was a real pain. I had to lower the front frame crossmember a bit to create some clearance to wiggle it into place. Torqued the crank bolt to 181 ft lbs per the shop manual.
View attachment 262376View attachment 262377
I need to get the valve cover back on still and I'm also replacing the radiator. Besides being covered in greasy smhoo, the old radiator is missing something important- a drain petcock. A new Denso one was only $60 so I went that route. I have the fans swapped over and got it sitting in place, but still have to hook up the hoses.
View attachment 262378View attachment 262379
Other than that and filling the coolant, this job is just about done. I'm really glad because it feels like it has taken forever and this was a very labor-intensive job without a lift.
