Replaced the distributor cap the other day. Got a Carquest one from work. It was surprisingly made in Japan. The old one didn't look bad, but it's a maintenance part.
One of the other oil leaks on this car that was pretty bad was the VTEC solenoid. I ordered the gasket from hondapartsnow.com and it arrived last week. I watched one how-to video where the guy had to remove the thermostat housing to access on of the lower bolts on the VTEC solenoid. Consequently he had to drain coolant and replace a bunch of seals and made a lot of work for himself. I didn't want to do all that work, so I modified a cheap harbor freight 10mm combination wrench so that I could get onto that one bolt without removing the thermostat housing. Worked beautifully.
Apparently I was not the first person to try to fix this leak. Whoever attempted it before me decided that it wasn't worth it to replace the gasket so instead they just globbed a bunch of RTV on it and put it back together. All that did was it gummed up the spool valve and made it leak worse.
View attachment 256531View attachment 256532
I got all the RTV out with a pick and brake cleaner and reassemble the whole thing with new gaskets. I thought I ordered the upper gasket from Honda, but apparently I didn't, so I used a Dorman one from the auto parts store.
To do this job, I had to remove the intake tube and upon removing it and inspecting it, I found a tear.
This intake tube is long discontinued by Honda and even if it wasn't, I'm sure it'd cost an arm and a leg. Junkyard ones are likely in the same condition, if they even exist. Fortunately, Dorman makes a replacement and a store that was 15 minutes away had it in stock. I got rid of the Dorman clamps and reused the original clamps, but the replacement tube fit perfect.
Unfortunately, while I was maneuvering it into place, I bumped and broke the plastic mounting point on the cruise control cable. I attempted to glue it back together but the glue wouldn't hold.
This piece is also discontinued and Dorman doesn't make this. I'm gonna have to source a used one. Upon further inspection of the cable, I noticed the pulley on the throttle body for the cruise is also broken- apparently a common problem.
Again, discontinued, no repop available. So I'm on the hunt for these two parts. Fortunately they won't sideline the car, but I won't have cruise control until I replace them. If anyone has a parts car or can find these parts in a U-Pull-It, I'll gladly pay you for your time to pull them!
I've also got a new OEM fuel filter here, but probably won't get to it till next week or so.
