Relative was going to be adding oil and just broke the seal on the bottle. While pouring it in he noticed a different stream and found that the seal went into his engine with the oil. Possible serious damage ahead or ????
Quote:
Just discussing this event on another board. Chances are that the seal went straight to the sump. Personally, I would drain the oil into a clean container and then pull the pan to try to find the piece. If he hasn't run the car, it "should" still be there.
Quote:
I've always worried that if I left my drain plug out too long a fly or wasp might go inside my oil pan and get trapped inside.
I prefer the Valvoline bottles as the rings stay fastened to the cap very well.
Quote:
When I pulled the valve cover for grins at 330k miles there was a plastic ring sitting pretty as you please on the top of the head. Maybe a little sludge isnt such a bad thing........
