So I'm over thinking. Should keep it simple, pick up a couple quarts of MC Mercon V at my distributor... but that's not oru way is it?
Finishing up some work on my 1996 Mustang GT with the Borg Warner T45 5 speed trans which is spec'd for Mercon. Ford now back spec'd Mercon V for all Mercon applications. I have run Mercon V in this transmission with fine results. I have a jug of Maxlife ATF on the shelf, and nothing else. Jug says Mercon LV on the back. I know valvoline's stance that maxlife is more shear stable and ends up operating at roughly the same viscosity as dex/merc.
Does anybody know if this T45 would be better suited by using a quality mercon/mercon V fluid like the Motorcraft or Mobil 1? I would expect both those fluids to be top notch and rather shear stable, with a higher starting viscosity. No transmission issues I am trying to cover. Car will be driven during late spring through mid fall only but will be driver with great spirit. Most seals are new. Always been a quiet and fair shifting trans. Not worried about service life of fluid but want to provide a good level of protection and also has the smoothest shifts reasonably possible. Thinking the thinner maxlife might increase notchiness? Never experimented before, what do you guys think?
