I don't think it's a bad idea to run Auto RX, I just wouldn't expect it to clean the underside of the valve cover or the rocker arms.
There are two real surprises.
The varnish is caused by vapor deposition. I don't expect Auto RX to clean anything unless it has constant flow over it.
Like compression and oil rings, which get hosed down by oil. Yeah right.
I believe that's more from the extreme heat and polymer breakdown.
I don't want to get off topic and get this thing locked so feel free to not answer me. Auto RX is a bunch of esters, right? Redline is an ester. I'm assuming RX has a few different types, some of which are better at cleaning than the Redline esters? You can see where I'm going with this, is Redline's cleaning ability underrated around here, because I don't hear much about it in regards to cleaning an engine.
