Bolt recall - What happens to the batteries?
Los Gatos, CA
Chevy is recalling the 2017 - 2019 Bolts to replace all of the lithium ion battery modules. Maybe 70K cars?
I am not sure what this really means, but I was wondering what is likely to happen to the recalled battery components.
I guess they are recommending not parking your car in the garage... Not good!
Is this an environmental problem? I did a little research but found nothing.
Perhaps @OVERKILL has some insight...
hopefully they'll get "recycled". there's a known defect in those packs, that can catch fire when they're charging.
they're not so much asking you not to park it in doors, just not to charge it indoors. that way if/when it does go up, it doesn't take your house with it....
with any luck, they'll go to a place like this:
Hopefully LG takes them back and recycles them, otherwise, just like with other waste, like wind turbine blades and solar panels, both of which can be recycled but aren't, it'll end up as landfill material, typically in some third world nation.
I guess I was wondering, based on the problem, can the materials be reused or repurposed? Or are they junk?
My battery subject matter knowledge approaches zero...
98% junk, some older battery technology can be recycled but no battery can ever be anything close to 100% recycled.
The majority of the EV batteries, power walls, scooters, bikes etc. are made from 26650 or 18650 LiFePo battery cells, these use a wrapped film chemistry (why they have the round shape), it is actually illegal to place them in a recycle bin as they are considered hazardous waste. Once dead, the EV battery will release additional hydrocarbon pollution via the "recycle" process, which consists mainly of the diesel emissions the cargo ship burns while transporting them out to sea to be dumped or to a 3rd world country to be buried by diesel burning dozers.
If the cells are prone to catching fire, no, reuse wouldn't be an option, nor would repurposing. They'd hopefully be broken down and have the valuable constituents extracted and the rest disposed of, but as I mentioned, unless that's financially lucrative, it is unlikely to happen.
The most likely economic outcome is to use them as stationary outdoor power storage away from urban center. Slow charge and discharge rate, near free price.
Even at lower rate of charge and discharge?
From what I recall, these cells are improperly assembled and actually short-out internally. According to GM, it's a manufacturing defect.
The National Highway Traffic Safety Administration said last week that the battery cell packs in the 2017-2019 Bolt EVs “have the potential to smoke and ignite internally.”
$1 billion jolt to the Bolt.
EVs are to cars what the Hindenburg was to aviation.
