Donald
Did you pull the lower unit and replace the impeller? I think it's good to pull off the lower unit yearly even if you don't replace anything.
One thing about keeping the boat in salt water is that the fish don't require an attractive paint job on the outdrive. Just some antifouling paint will do.
I have had both and the engine drive raw water pump seems like a better design than the way Mercruiser does it with an Alpha One. However if the prop were to hit a rock and bust up some gears the Mercruiser Alpha One is easier and cheaper to repair.
