This is not exactly a lubrication question but definitely boating, so only partially off topic.
Finally this weekend I got my boat out. The last trip was exactly a year ago with lots of water skiing etc and the boat ran great (2003 Bayliner 175 with 3.0L I/O). The boat was winterized last fall.
I cranked very long and it failed to start. I realized that one spark plug wire was left disconnected (sloppy me when I winterized). When I reconnected, it started with the usual smoke from winterizing oil. Here are the surprises. The oil pressure gauge stays below zero and the tach is dead. I stopped and troubleshooted and found that oil was full, the oil pressure sender worked but the gauge was dead. I hesitated some but decided to go boating because wee had friends from out of state and wanted to take them to the lake badly. When I launched the boat it turned out that the trim gauge was stuck in the top position (but later unstack and it works off and on now). The water temp gauge was also stuck at 100F. Worse, we could not get on plane with decent RPM by engine sound, I was afraid to push it without a tach.
I realized that there would be no skiing and I anchored and kids swam a while. Suddenly, it got cloudy and stormy and we had to scramble back to a shore at only no wake speed.
Since the rain continued and was getting late already we pulled the boat on trailer and hurried home. While driving I heard some noise from the trailer and realized I got flat tire. Before I pulled to the shoulder (from 70 MPH) the tire was shredded and smoking. Took me forever to replace the tire for many reasons but also because it was dark and raining. BTW, the tires were in great shape (great tread and little weather checking) and inflated to the nominal 50 psi before I left, but clearly old at 7 years of age (I was planning to replace them soon).
Here are my questions:
1. Am I the only one with bad luck with Faria gauges? I already replaced the tach and Voltmeter gauges once under warranty. The speedometer newer worked right.
The fuel gauge is also flaky and never goes back to zero when turned off. Is there a better vendor and would other gauges be compatible? I would not mind replacing them all.
2. Did I fry the gauges by cranking with one spark wire disconnected? Or is it just from age and boat sitting in a hot place?
3. What's with lack of engine power, and inability to go on plane? Is carburetor messed up? Could old gas do it? I kept full tank (like instructed) with stabil in it. Now the gas is one year old. I did that in the past and had no issues before. I guess I need to drain old gas. Which brings me to the next question:
4. How do you drain gas from boat? Is there some kind of gas pump that can be utilized? I have a cheap tubing with squeeze bulb that doesn't seem to work.
5. I realized that car tire jack is hardly a match for boat weight. What do you guys utilize? Hydraulic jack?
6. I need new trailer tires and heard good and bad things about Goodyear Marathon radial trailer tires. Probably the only trailer tire still made in USA. Chinese trailer tires are universally hated. I can get them for $69 at tirerack. Is there a better tire?
I know this is a lot of questions and thanks for any input.
