I just has work done by a small BMW ONLY repair shop on N52K 3.0si engine.
They put PINK coolant into it ... I looked at the bottle it states OAT G12+... (PN-C-40007, ASTDM 3306 ASTDM 4656)
I have the impression this can damage head gasket... BMW OE
uses (not that colors are indicative of anything these days) blue G11 whch I believe is IAT technology..
I read OAT must not be used for BMW as it can damage gaskets...
1. can the team at btg shed some educated light on it if I should rush to do the change ASAP...
I am totally upset and I am thinking of draining coolant and flushing with distlilled water.
2. I would do today but there is electric pump so despite following bleeding procedure I have
the fear that if once I remove coolant from radiator and replenish pressurized tank with distilled water
I could IN THEORY by crap shoot not get no coolant to the pump immediately and it could seize)
I think blue (I think BMW uses G11) and G12+ must no be mixed. I am thinking
just draining radiator (thus leaving several gallons in engine) is a problem as G12+ in the engine would mix with the BMW blue G11 being added.
So it seems I have to first add distilled water and keep removing water until almost all G12+ is removed... only then I can add Blue BMW OE
3. Deos anyone have a handy link documenting the TOTAL amount of coolant there is in BMW X5 3.0si E70 2007 and G12+ coolant?
Someplace it states 2 gallons, some places 3 gallons
I would appreciate knowledgable answrs here from people versed in chemistry more than I am
I should have kept check on ALL and asked on BTG before letting them just do their stuff...
One would think you can just relax and rely on some people to do a professional job
Some people have similar issues:
https://www.youtube.com/watch?v=1nUMqwma77E
https://www.pistonheads.com/gassing/topic.asp?h=0&f=23&t=1423949
