wemay
Site Donor 2023
http://jalopnik.com/bmw-m-boss-says-high-powered-automatics-will-even-kill-1794558556
While fueling the need for cars with more horsepower, BMW’s M-division seems to have backed itself into a corner when it comes to offering a variety of transmissions. In a recent interview, a BMW exec indicated that the days are numbered for manual and DCT gearboxes.
Australian car blog Drive (not to be confused with The Drive), spoke with BMW M’s vice president of sales and marketing, Peter Quintus, about the future of manual and dual-clutch gearboxes and things do not look good.
Quintus says that durability concerns are the primary factor that may mean the end of three-pedal and DCT options in BMW’s most powerful models. He says that either transmission simply can’t handle the power from a long-term reliability perspective.
Of course, Mercedes has figured this out long ago with their AMG models that the only way to reliably deliver the insane amounts of power and torque was to use a conventional torque-converter automatic. Even though the DCT used to be able to shift faster, the new generation of automatics have closed that gap significantly. Here’s what Quintus said, from Drive:
“We are now seeing automatic transmissions with nine and even 10 speeds, so there’s a lot of technology in modern automatics,” he said.
“The DCT once had two advantages: it was light and its shift speeds were higher.
“Now, a lot of that shift-time advantage has disappeared as automatics get better and smarter.”
In regards manuals, Quintus is of the opinion that around 450 horsepower and 440 lb-ft is more or less the limit of manual gearbox durability, and once you hook up manual setups to motors that exceed that mark, longevity cannot be guaranteed. Now, this sounds quite odd considering here in America you can get manual gearboxes in cars with up to 707 HP.
So, why doesn’t BMW just use the U.S.-made transmissions that are clearly built with U.S. might and fortitude? Quintus told Drive:
“We looked at US gearboxes. We found they were heavy and the shift quality was awful.”
While I wouldn’t call the shift quality in a Corvette Z06 awful, it is true that you can’t have it both ways in terms of having a light shifter and a clutch that can handle over 500 HP.
Quintus closed the interview by telling Drive that he’s “not even sure the next generation of M3 and M4 models from BMW will have the option of a manual gearbox.”
Perhaps if BMW drivers really cared about keeping their manual gearboxes, they wouldn’t be so obsessed with having more power than their neighbor with an AMG Mercedes.
