This is a VOA of the current BMW 5w30 synthetic.
the bottles production code is M060417A54.
Sample date 03/31/2006.
This was a clean 5w30 oil in which no problems were found in the analyisis. Only a trace of insolubles were found which really isn't unusual for a virgin product.
The additives are typical of other samples we have run for this oil. the TBN was 10.6, plenty high, and a good point to start out from if you intend to use this oil for extended use. 1.0 is considered too low. This oil should serve your gas engine needs well.
Blackstone comments:code:
Aluminum 3
Chromium 0
Iron 0
Copper 0
Lead 0
Tin 0
Molybdenum 126
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 1
Boron 53
Silicon 6
Sodium 2
Calcium 2612
Magnesium 6
Phosphorus 717
Zinc 838
Barium 0
SUS Vis @ 210F 64.7
Flashpoint 445
Fuel 0
Antifreeze 0
Water 0.0
Insolubles Trace
