2018 M240i with the 6 speed. Parked the car, put it in first, and shut the engine off. Heard a lot bang from the rear. Thought, "Crap, I lost a spring." Checked the car out, pushing down on each fender-no issues. With a flashlight I crawled under the car. All looked good, the springs and shocks looked fine. No leaks. Checked the serpentine belt; it was fine. Scanned the car with bimmerlink. Bunch of electrical codes, and found 2 codes: 213A2D ("dual mass flywheel, protection; harmful operating point detected") and CDA505 (ignore as the car doesn't have EGS). See the attached pic. I tried to clear all of the codes but these two codes would not clear! I took the car for a short spin. It shifted fine, no noise, no jerking, nada.
I contacted a friend of mine who is a BMW master mechanic. He's in NC and noted that the clutch may need to be replaced.
The car has ~36k miles on the odo. Tracked 3x. Original battery.
Did some research on the net, and some pointed to the battery. I don't think it's the battery.
Any ideas?
Thanks!
Any ideas?
Thanks!
