This is the car I recently posted a UOA (2013 328i N51 engine) showing some elevated Aluminium and Iron. That analysis also showed some fuel and had a pretty low flash point. I've recently replaced one coil pack and just last week had some additional misfires so I just put in new spark plugs which seems to have solved the misfire issue. I thought I'd do an early oil change now it's running right.
In doing this change, I found something strange with the oil filter. When I unscrewed the oil filter cap, the filter and little plastic cage stayed on the car. Normally, the filter is supposed to come off with the cap as is the plastic cage that holds the filter... Furthermore, the filter itself looked a bit squashed. So I'm wondering if the filter may have not been installed correctly and if it was letting unfiltered oil circulate in the system, hence may have caused the elevated metals in my UOA? Unfortunately, I'm the one who put that filter in a year ago and I don't recall anything unusual at the time...The old filter was a Bosch but it doesn't have any reference numbers I can look up.
I was able to reinsert the plastic cage back into the oil filter cap where it seems to hold on by clipping in with some plastic prongs on the cap, but it is very loose now. Is this a problem and do I need to get a new cap or is this loose cage OK?
