BMK11 bypass adapter
Long Island/New York
I found the Perma-Cool sandwich adapter that has a 3/4"-16 threads but uses 1/2 inch lines.The Amsoil BMK11 bypass kit uses 1/4 inch lines.I've looked under my 06 Jeep with the Hemi and there is not one place to mount this kit.Joe
Sure there is. Don't just look under your jeep. Just look for a place where there is a space and lash it to something that doesn't move. Near the master cylinder ..to the air box plumbing ..etc. You use zip ties (not something that would normally occur to you, I know) ..and just leave enough slack to put a pan under it when you want to change the filter. Tie the excess line to something too. Cut as needed ..when done ..lash fast again.
Lot's of members do this.
