I did say 3.5 mm.I did find a headphone jack on my laptop, although it's a lot smaller than the ones shown in earlier messages.
Yes you did. Moot point though as the headphones don't work in the jack. At this point, I don't know what the problem is, and it's not a good time to dig into it. Regardless, I learned something about my computer, and that's a good thing.I did say 3.5 mm.
my uncle used to dj waaaay back in the day and once told me a good eq should resemble a smily face.Speaking of equalizer, some portable BT speakers come with an app that allows you to tweak the EQ right through your phone.
This Anker Soundcore Motion+ is one of them:
Review on rtings:
Anker Soundcore Motion+ Review
The Anker Soundcore Motion+ is a small and lightweight speaker that's easily portable. It's well-suited for outdoor use thanks to its over 15-hour battery life a...www.rtings.com
True, to some degree - at low volumes, human hearing is deficient in very low as well as very high frequency ranges, so boosting these frequencies may be of some benefit. However the main benefit of an EQ is to compensate for those frequency areas where your system is lacking, and this will vary greatly depending on the particular system as well as the room in which it is placed.my uncle used to dj waaaay back in the day and once told me a good eq should resemble a smily face.
I have that speaker and it doesnt have all that much bass. However if it's too much for you maybe you can adjust it like was mentioned. What laptop do you have and what operating system does it have ?Which one do you have now?
Anyway, take a look at this Anker one:
In addition to Bluetooth, it also has aux input, so you can wire it directly to your computer and potentially achieve better sound quality.
Or be like Bose and tune everything to be heavy in the mid-lows and target the older crowd who tends to lose hearing for the highs.True, to some degree - at low volumes, human hearing is deficient in very low as well as very high frequency ranges, so boosting these frequencies may be of some benefit. However the main benefit of an EQ is to compensate for those frequency areas where your system is lacking, and this will vary greatly depending on the particular system as well as the room in which it is placed.
Not defending Bose, but general pop and rock and classical recordings tend to be deficient in Bass, and there can be phase cancellation of lower midrange and upper bass so BOSE are compensating for that to get a more realistic tone balance in the home.Or be like Bose and tune everything to be heavy in the mid-lows and target the older crowd who tends to lose hearing for the highs.
