On a typical single piston caliper the bleed valve usually is located at the top of the caliper near the brake hose attachment point. When bleeding brakes does the brake fluid flow from the hose connection right to the bleed valve leaving the majority of old fluid sitting in the caliper? I assume it does so I bleed brakes first, then compress the caliper piston with the bleed valve open to push out the old fluid. Not sure if that is overkill but feel better knowing the caliper gets refilled with fresh fluid. I would guess that calipers that have the brake hose attach to the bottom of the caliper with the bleed valve on top might be "self flushing" due to the design/fluid path. Anyone know for sure?
