Bled the brakes before a pad slap?
never done it before the pad and rotor change, I do it after. I drain the reservoir first then pump new fluid through the system from a re-filled reservoir. I start at the RR and then LR, RF, LF. Furthest from master cylinder first. Flush until fluid runs the same color as the new stuff.
I use an old peanut jar and a clear plastic hose to avoid getting air into the system from the bleeder screw. Works like a charm.
Was doing a pad slap on the front brakes. So decided I would bleed the front brakes first - so when I compressed the calipers I didn't push all that old gunky fluid into the ABS control valves. Only added like a minute to each side with the wheel already off.
Bled them after as well.
Anyone else do this?
Some do a modified version. Open the bleeder before compressing the piston(s).
Your brake fluid reservoir should never overflow…unless you overfilled during a brake fluid service.
This is people who can't help but "top off" the fluid even though it is above the MIN line. The fluid should be at MAX with new pads and then normally it goes down toward MIN as the pads wear causing more fluid to stay in the calipers.
The fluid doesn't circulate, but it sure gets a lot of "back and forth".
Think of the number of times the pedal is pushed on every drive, and the action within the system that takes place with each push.
With that in mind think of what can happen when the pedal is pushed beyond it's usual travel, during a manual bleed.
Pushing the pedal to the floor moves the master's internal seals into sections of the cylinder they haven't been to for a very long time, that may damage them. The master can go belly up.
Using a pressure bleeder is the only way to go, especially if the fluid has been nasty for a long time.
I have heard this claim many times over the decades but never heard anyone say they had to replace a MC because of excess pedal travel.
…Pushing the pedal to the floor moves the master's internal seals into sections of the cylinder they haven't been to for a very long time, that may damage them. The master can go belly up.
I've seen it happen - it's a tough call to a customer explaining the newly acquired need for master cylinder replacement.
