Bled the brakes before a pad slap?
I've never done a brake fluid bleed at the same time as a brake pad change. But I follow your reasoning, and it makes sense. The brake fluid right behind the brake piston is always the nastiest, since it gets more contamination.
  • Like
Reactions: Arc
never done it before the pad and rotor change, I do it after. I drain the reservoir first then pump new fluid through the system from a re-filled reservoir. I start at the RR and then LR, RF, LF. Furthest from master cylinder first. Flush until fluid runs the same color as the new stuff.
I use an old peanut jar and a clear plastic hose to avoid getting air into the system from the bleeder screw. Works like a charm.
I always open the bleeders, to compress the caliper. Then i let them drip onto a pizza box , or cardboard box. Slow way of flushing the older fluid out. When done, i burn the boxes.
Sometimes I do, sometimes I don't. I change brake fluid whenever I feel it being mushy and brake pads when it runs thin. If you do them frequently enough it doesn't make a difference to me.
  • Like
Reactions: Arc
Sounds like a great idea to me!
I always open the bleeder before retracting the pistons too, no need to force that crud back toward the reservoir.
Then, bleed after and you're good.
