Recently in our condo. whenever any faucet is turned on with hot water, there is a terribly annoying whistling noise coming from the copper pipes after the water heater, I am pretty sure it is either the mixing valve or the ball valve which brings the cold water to the mixing valve. Any other possibilities?
Never worked with copper pipes before, they kind of look soldered in?? Are they straight forward to replace? Any help would be greatly appreciated.
Video of the noise. (lower your pc volume before hitting play)
http://www.youtube.com/watch?v=tZca84FQWCI
