Well bio is not totally banned now in the Eastern TxLED counties, in this document
http://www.tceq.state.tx.us/assets/publi...l_producers.pdf
producers are limited to 100,000 bbls of 100% bio production to be used as B20 blend in the 110 TxLED counties, basically anywhere East of I-35. At 20% blend that makes 500,000 bbls of fuel per producer, or 21,000,000 gal. per year. (using 1bbl=42 gal, 420,000 gal limit /year)
West texas will be where you can get B100 it looks like.
This looks a lot like a compromise, enough people complained that they decided they better compromise and better to shut up the majority while still giving concessions to big oil as that B20 still has to be 80% Tx LED diesel and a cap is put on the bio competitor to roughly less than half the production of a small bio-production plant. In this way they intend on limiting total bioD consumption to less than 1% of total consumption in this area by the TxLED's own documents. (2) Guess the rest will have to go to West Texas. I still smell collusion, or they are hedging their bets as they have conflicting reports from two government agencies. * Though in the above cited document (2), they are still touting the EPA numbers of 2% increase in NoX.
(2)
Biodiesel Industries advertises a standard modular production unit with 10Mgpy capability. Renewable Energy Group is building 60Mgpy plants in Kansas and Iowa.
If you look at the permits given out so far, only producers of both bio and regular diesel have recieved permits for supplying the TxLEd districts. One plus is that you can pretty much bet on getting good clean fuel in the TxLED area with requirements of a min Cetane of 48, where before I know sometimes this was not always the case. No additional requirements on over national standard on lubricity however.
http://www.nrel.gov/vehiclesandfuels/npbf/news.html
*"A recent NREL study concludes that vehicles using B20 fuel—a blend of 20 percent biodiesel and 80 percent petroleum diesel—do not produce an increase in nitrogen oxide (NOx) emissions, unlike an Environmental Protection Agency 2002 report showing a two percent increase in NOx emissions for B20.
"This is a major finding because the perceived small increase was leading some state regulatory agencies to consider banning B20 biodiesel," said Robert McCormick, NREL principal engineer for nonpetroleum based fuels research. "Our study helps remove a significant barrier to the expansion of biodiesel markets." ...
"Our study shows that the NOx impact of B20 varies with engine design, such that some engines show a small increase while others show a small decrease. The EPA's 2002 review was based on a data set made up primarily of data from one engine model that produces a small NOx increase. EPA uses these data to draw a general conclusion for on-highway engines that B20 causes a 2% increase in NOx," McCormick said. "The chassis dynamometer testing along with careful review of previously published data suggest that their conclusion is not correct, and that on average B20 has no effect on NOx." "
