Truck was a mess from that last snowstorm. Decided to use Touchless. No contact wash. Stuff is pricey but works great.
I got underneath as much as I could.Looks nice, But what about the underbody?
I moved out of NJ a few years ago but I still know they salt the roads.
Clean Garage or Carzilla. This time Carzilla.where did you acquire bilt hamber products in the states? Carzilla up in Canada has it but oos.
It's the only prewash that actually cleans very well. It's also safe (sugar based). It's perfect for times in winter when you can't do a full wash but want to remove 90% of the grime/salt/dirt off the paint. Rinses off very well. Leaves nothing behind.
I like Carpro Descale. That's the only acidic soap I've used. Cleans really well.It's strong stuff, no doubt. Bilt Hamber is one of the few really results and science first brands. I've been really impressed with the effectiveness of acidic soaps as well for bringing back the hydrophobics on sealants and coatings. Labocosmetica Purifica and the yellow Adam's Strip Wash are both good. Purifica is strong stuff.
Have the ants come around?Clean Garage or Carzilla. This time Carzilla.
I picked up an IK Pro Foam 12. I also use a Marolex pump sprayer. Either method works. It's considered to be the best pre-wash on the market.Have the ants come around?
I need this stuff. We’re in the same weather patterns and roads. What is the sprayer you use??
I’m using touch-less, so low pressure shouldn’t be an issue.I haven't noticed much of a difference between foaming it vs sprayer. Some say foaming works best on dry car. They say you need to pressure wash it off too. I've tried the hose and it didn't cut it. There are some that say Auto-foam works better on different dirt types.
The just released a new version that has 2x the cleaning power. I have the older version.
I w been thinking a bit more about this. Most road grime will come off with a pressure washer and yellow tip, it just won’t cover enough area. I don’t see how some chemical is going to change this.I haven't noticed much of a difference between foaming it vs sprayer. Some say foaming works best on dry car. They say you need to pressure wash it off too. I've tried the hose and it didn't cut it. There are some that say Auto-foam works better on different dirt types.
I agree with you in that the pressure washer and water (which is a solvent) works to some extent. I've seen many videos though were it worked extremely well, some up against other products and a control (just water). While it can remove substantial grime, a contact wash is still necessary IMO.I w been thinking a bit more about this. Most road grime will come off with a pressure washer and yellow tip, it just won’t cover enough area. I don’t see how some chemical is going to change this.
Our cars weren’t washed since before Christmas. Maybe that’s the difference? The road grime is “embedded” enough that it just absolutely requires mechanical agitation?
Again, my assumption for now is that it gently gets at least a bit more dirt off, and that the corrosion inhibitors are leaving something worthwhile…
If the road film is actually salt and mineral buildup an acid product will work better. Adam’s Strip Wash (yellow) is the most easily available one. Labocosmetica Purifica is what I use mostly now though. I’m not sure anything safe will truly work touchlessly, however.I w been thinking a bit more about this. Most road grime will come off with a pressure washer and yellow tip, it just won’t cover enough area. I don’t see how some chemical is going to change this.
