The MANN W71220 should work in place of a Ph3614 in an engine that requires a higher bypass valve setting.
Part Number: 51288
UPC Number: 765809512887
Principal Application: Audi Quattro, 5000 Turbo (84-88) Turbo Filter
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 30
Burst Pressure-PSI: 310
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
PH3614 sized in WIX
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-09), Various GM, Saturn (85-07), Lexus (90-09), Saab (67-09), Suzuki (86-02), Toyota (88-09), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Nominal Micron Rating: 19
Gasket Diameters
