I am brand new to this board and need some help fast. I have many years of engine building experience and am no stranger to oil related problems. Oil has changed many times since I started my car related activities 40 years ago.
Here is my problem. The car is a 2000 Dodge Carvan we bought new and have change the oil regularly at 3000 miles. We do live in a hot climate( West Texas) and most of our trips are short. I have had the car serviced at a friends service station since new. His Texaco station carried Havoline in bulk so that is what we used. About a year ago, he closed down. Rather than go to an oil change place, I change my own. I bought a lift for the shop and love it.The 3.3 motor has about 110,000 miles on the clock. I use good filters. The last oil change (1300 miles ago), I used Valvoline 10w-30 and 1/2 quart of Lucas oil additive. I have had very good results with Lucas in my Jr dragsters. I built my own engines and saw very little wear using Mobil 1 and 1 oz of Lucas in my 7.90 motors.
Friday night my wife called and said the oil light was on in the car and it was even "dinging' at her; meaning the warning bell was going off. I told her to pull over immediately and she said " NO, I'm almost home, anyway." As I ran out into the garage, she was just pulling in the garage. As she slowly and carefully parked the car as usual, the lifters were banging like crazy. I'll skip the part where I end up sleeping on the couch because I upset her and go to the problem with the engine.
I trailered the car to the shop and upon start-up, the lifters got quiet(engine was cold). I attached a mech oil pressure gauge and it had 60 psi cold and went down to 25 hot, well within factory specs per the service manual. I dropped the pan and the pickup was so stopped up, you could not even see the screen. There was a hard carbon like buildup coating the entire inside of the engine. It looked like something was trying to clean up all the build up and instead of it dissolving and mixing with the oil, it just flaked off in pieces the size of a pinhead or smaller. Some of it is still there and some was in the pan like sludge.I had to use lacquer thinner to remove the hard coating from the pan. I sprayed some brake cleaner into some areas around the cranks and block skirts and that helped take some of the coating off.
As you can well imagine, the valve cover looks as bad or worse. I can only get to one side and the intake is hard to get off as well. Pulling the engine to clean is not a viable option. Changing the oil and giving her back the van is just waiting for the same thing to happen. She only drove the car about 6 blocks with the bell going off, so we may be ok on the motor. If she had been across town, we would not be having this discussion. The motor would be locked up.
I have had the problem once before with a Dodge 360. The man I bought if from said he changed the oil ever 3000 with Pennzoil. I changed to another brand oil( can't remember the brand) and it flaked off and stopped the pickup completely. I was changing the motor to a Cummins anyway, so it was no loss.
Now for the questions. What caused this in the first place. What made it come off, the Valvoline or the Lucas. Should I use some sort of motor flush, automatic transmission fluid or what? The pan is easy to drop so a look-see after I flush is easy. I cam post some pics later on tonight. Any help would be appreciated. Mark
