Does anyone have any technical data on this product or experience using it in a manual transmission? I can't seem to find a product data sheet for it. All I could find was this generic statement...
"BG Syncro Shift is an all synthetic gear lubricant specially formulated for front wheel drive manual transmissions. It does not sacrifice any performance as does engine oil, ATF or conventional gear oil. It provides required thermal stability, low-temperature fluidity, hot rattle suppression, noise dampening at operating temperature, outstanding extreme pressure characteristics, shear stability, smoother shifting characteristics, wear reduction (synchronizer, gears, bearings, shift fork), seal compatibility, and reduced maintenance costs."
