A well-known Volvo shop around here uses this particular ATF in transmissions which require JWS-3309 specification. The shop owner also claims to use some additive by this company which I forget the name of, but he makes claims that it works better in Aisin-Warner automatic transmissions than Mobil 3309.
I have always used 3309-compatible ATF and this BG Products stuff makes no claim to this. It is, however, a synthetic fluid. I find compatibility a little hard to believe, as the guy was also recommending I flush my transmission at the same time when I was simply making an inquiry on if I could buy Mobil 3309 from him. He also claims Mobil 3309 does not hold up as well in A.W. transmission as this B.G. fluid he is using. I notice they also sell flush machines on the same page....hmm...should I be weary of this guy's recommendations? I had no plans to change my ATF anyway since I just did it recently, but I've never heard recommendations such as his before, so I'm seeking your opinions on this particular ATF, noted in the title of this thread. Thank you!
The fluid info that I could find is on this page: http://www.bgprod.com/products/transmission.html
