I have an Infiniti Q45 and it's time for the trans to be serviced. I serviced my trans back in June '06 with a drain/refill. I put a lot of highway mileage on my car when I was in college and I drive back & forth from Oklahoma to Alabama all the time. Plus I drive 100mi total commute to my job and back to my house M-F. I estimate that I've put close to 40k highway mileage on the transmission fluid that's in now so it's time for a change.
I want to put Synthetic Mobil 1 ATF in my car now because it deserves the good stuff. Even though the bottle says Mercon V, it also states Multi-Vehicle formula and it would be ok with my trans specs of dexIII. I've purchased 16qts and plan on taking it to a local shop here so they can use the BG Flushing system on my car. I've heard & read nothing but good things with the BG system. Is it ok to use the BG system for my car or just do the drain/refill method? I really don't want to do the drain/refill because I want to get all of the oil ATF out and replace with Mobil 1 ATF.
Thanks and happy to be on board...
