Originally Posted By: alarmguy
Originally Posted By: mjoekingz28
It seems the consensus here is that oils are so much better than they were 10, 20, 50 years ago- but how do we know? Could it just be the engines are made with different metals and designs?
I dont know but it seems its how they work together and not necessarily one or the other.
Case in point. The viscosity chart from a 70s Camaro had 7500 mi oil changes. Seems until just recently that was the top end of todays OCIs. Now, 10-15 on Full Synthetic for highway commuters seems normal.
Its a good question and off the top of my head without too much thought I would say.
1- New oils are far superior to oils of even a few years ago, never mind decades ago. My reasoning would simply be, the API requirements are so much more robust, in relation to wear, sludge, engine cleanliness and whatever else. It does not compare to API of decades ago where the technology did not exist to make such oils.
2. New engines are also far superior to engines of decades ago. Lubrication systems, cooling systems, fuel systems are all so much more superior then the days of designing engines on a draft board vs today where computers design engines, as well as manage the engine in the vehicle for peak efficiency vs decades ago of carburetors dumping fuel into an intake manifold.
3. As far as that 70s Camaro, if correct on the 7500 OCI, well, back then, you would be pretty lucky if an engine lasted (or didnt burn oil) as long as 75 to 100,000 miles, Now if an engine fails at 100,000 miles it can almost be considered defective.
Today's engines aren't far superior, they are marginally better. You used to have a cast aluminum piston in a cast iron bore. Now you have a cast aluminum piston in a cast iron bore. Clearances are dictated by materials ie growth of piston in the bore. Chevy had the powdered metal rods forever and they are very strong.
Advances have been made in port design but aftermarket heads are available for the sb1 that do the same thing. I could put together a old sb1 that would be every bit as good as a new design.
For every camaro that started smoking at 75k miles you'd find a pickup with 300k miles.
I agree though, that new oils are far superior. You don't see them gelling up in the oil pan as much on neglected oil changes.
