HTSS_TR
Originally Posted By: HTSS_TR
According to Ultra Gauge instant MPG (similar to Scan Gauge), my '00 E430 consumes less gas while coasting in neutral than in gear. Existing highway at speed around 60-65 MPH coasting to red light ahead, my Ultra gauge shows 120-130+ MPG in neutral and 70-80+ MPG in gear. Also, I can start coasting in neutral about 1/8-1/4 miles farther than in gear. I thought that with OBD II equipped engines the fuel is cut off while coasting in gear. Remember that this particular exist lane near my house is about a mile long, it was safe for coasting down from 60-70 MPH to about 30-35 MPH at the end of the lane.
Can someone with Ultra gauge or Scan gauge confirm what I experienced ?
Originally Posted By: Vikas
You have to understand that UltraGauge "computes" fuel consumption. It is NOT reported to it. It does that based upon MAF reading and engine speed and engine load. When MAF is not available, it uses MAP reading and assumed volumetric efficiency. It does NOT know the fuel injection pulse width. If the engine is cutting out fuel during the engine braking and/or coasting, UltraGauge will NOT show it.
Coasting in "N" on an automatic is fully retarded, I can not emphasis that enough and I used the term "retarded" intentionally. Don't do that.
- Vikas
I have UltraGauge for few months, I liked to know how to drive more efficient without endanger myself and other drivers on the road. I know that at any given time, driving or cruising or coasting, it is safer to have the transmission in D not in N. Saving few ounces of fuel per trip is not worth the danger to have the transmission in N. I was interest in confirming the fuel cut off when coasting in D, versus some fuel use with transmission in N, and I thought that UltraGauge is the tool to confirm that.
From your post, I agree that UltraGauge could not calculate the instant MPG correctly when you take off the foot from gas pedal to let the car coasting to a stop. That is okay with me, knowing the deficiency of the tool will let me adjust my expectation of the result displayed on the gauge.
- Vikas
