Better HDEO than SynPower?
Duval Co. Jax FL, USA
I read up on some HDEO Oils, as per suggestions. Seems SynPower 20W-50 is the only one that contains PAOs, other grades Dont.
If that is the HDEO preference, ill get that and mix it with some lower-grade so my Engine equals out at 10W-40 and is happy, getting Cleaned as well.
Any HDEO Suggestions?
This is the 94 Probe i put Moly in, then MMO. No additional Moly and no initial MMO.
IF you are looking for a HDEO use either Rotella T, Delvac 1300, or Delo 400 in the 15w40 and do not add anything to it (no moly and no MMO). And no, you do not need any PAO and the SynPower 20W-50 has very little PAO in it. Do try to be a chemist, let the professionals that designed the oil do the work for you.
Syntec 20w-50 has extra zink.
Valvoline ZR1 or SynPower Racing
Rotella 10w30
Plenty of options w/o mixing.
