Alright, in the past year, I've been through about a million routers. The orignal was a Netgear Wireless G something or other, [censored] and had to be reset 3 times a day. Replaced it with a Cisco-Linksys E1000. It did great for internet surfing, and basic stuff.
But streaming Netflix to the Blu-ray player, or trying to game on it, didn't work quite as well. Netflix was unusable, and gaming worked okay, but ping times were a bit high.
Ended up replacing that with a Netgear WNDR3700. Great router, great range, fantastic performance on both 2.4 and 5Ghz bands. Handled everything we threw at it. Till the 2.4Ghz radio died after about 4 months.(A somewhat common problem on this router), exchanged it under warranty at Best Buy (They'll replace under manufacturer warranty with a different model)
Ended up replacing it with a Netgear WNDR4000, and payed a little bit extra. Wireless worked great... Wired connections however, were slow for some reason. Pages loaded very slowly compared to the the WNDR3700. Unhappy, I replaced that under the 30 day return policy with a Cisco-Linksys E4200. Same problem. I later found out that the E4200 and WNDR4000 both use the same Broadcom chipset. Latest firmware on both. It could be just a fluke but... Once again, replaced under return policy with another WNDR3700. As long as the radio holds up (v2 has supposedly helped to fix the problem), this is my favorite router by far. It isn't the most expensive (Still pricey at ~$130) but range is very good, speed is good both on wired and wireless. The only real complaint I have is that the USB NAS Port has very slow read/write speeds that make it not usable for large file transfers. A dedicated Ethernet NAS is still the best option there.
A mature version of DD-WRT is also available for the WNDR3700, though I've yet to load it on this one (did on the last one). I might consider it in the future, but for now I'm leaving it alone. So that router is my recommendation, the Netgear (N600) WNDR3700. The 5Ghz band is only 300mbps, but honestly, who needs 450mbps, and how many people have or are willing to shell out for the adaptor needed to use it? The speeds advertised are false anyway, theoretical in nature. So that is my recommendation for people who need a high-performance, long range wireless router.
http://www.smallnetbuilder.com/wireless/...router-reviewed
