What's the best practice for flushing the brake fluid without changing brake pads at the same time?
Probably when the pads get changed (in the fututre) the level of the brake fluid will rise, so is it better to fill till the "Max" line and remove fluid after the pads change or to mark the current level of the fluid and fill the reservoir up to it?
(I'm asking because currently my car's pads are about 50% worn but the fluid is already almost 3 years old).
