Do 20 year old cars exist in Massachusetts? I would have thought they rusted away long ago?
Probably if they were from outside the rust belt and from the south / California etc.Do 20 year old cars exist in Massachusetts? I would have thought they rusted away long ago?
Mazda from the head gasket down? (We have a 2012 Mazda 2.0.)Fusions with simple 4 cyl mazda engines seem to go and go? Reasonable comfort and fuel economy. Not the simplest to work on but I seem to figure it out.
Standard procedure for lithium fires: Let it burn.Has no-one thought of an EV? They're an ideal commuting vehicle.
A used Tesla Model 3 would even be cheap. And a 90 mile round trip with daily home charging would be easy.
That was the Focus with the DCT, classic auto trans on the Fusion which is durable.Mazda from the head gasket down? (We have a 2012 Mazda 2.0.)
Oh, but that Fusion DCT that cannot be fixed.
If it were me, I'd say OP is on the right path looking for a manual transmission Accord.
These rot in the rockers, every one. Go south maybe?Fusion with 2.5 engine
The 6F35 on the Fusion will often have a bad 2-3 shift... slow to shift, then finally shifts with a jolt. I had a 2013 with 175k miles and it did that. Pretty common on the message boards. I think my in-laws have an Escape with the 6F35 and it does it too, although they haven't noticed.That was the Focus with the DCT, classic auto trans on the Fusion which is durable.
Every one, or just the first gen? I haven't seen many 2013+ with a lot of rust. But definitely a problem spot on the first gen.These rot in the rockers, every one. Go south maybe?
2010-2015 Prius (and Prius V) with 1.8L has the highest rate of head gasket failures. 2009+ Corolla, Matrix, Pontiac Vibe, and Scion xD of that era are also known for head gasket failures on same 1.8L, but Prius holds the crown for highest rate of failure still.If EV is not desirable then a gen 2 Prius would likely be a good choice. A new $5k battery when it is 15-20 years old will still be way cheaper than extra gas vs a Corolla.
@SC Maintenance believe it or not they do! Usually the ones still alive are grandma's old Camry that was parked in the garage for all its life. What I wasn't expecting is the price of used cars up here! Not that I've looked too hard but even a 20 year old Camry/Accord that looks decent and has less than 200k miles goes for $5k plus!
My brain still thinks it is 2019 when people practically gave these away.
How much are you looking to spend?> What is your price range?![]()
Honestly I'm just kicking tires right now wondering if it is even worth it. I was hoping $2k would get a higher mileage 2000's era commuter known for reliability and in decent shape. I think it is going to cost me double that unless I want a beater or a rust bucket.
Just started looking though. The correct answer might just be to keep driving my 21 GMC Canyon and rack up the miles.
That is what I wanted for my 100 mi daily commute with free charging at work.Has no-one thought of an EV? They're an ideal commuting vehicle.
I seem to recall that they weren't really too bad, at least when they were a couple years old. Marsh mellow ride, pretty quiet engine, basically CUV seating position, much more headroom than a Corolla or even Camry of that era. I remember test driving all 3 and they basically felt like the same beige thing in 3 different shapes....You might like this Echo![]()
I don't think a Tesla with 300,000 miles would be a good choice - unless it has a newer battery. A Model 3 might make 300,000 miles on the original battery but even if it's still working well there probably isn't too much life left on it and a replacement battery would probably cost more than the car is worth. [Though you could have the battery's capacity tested by Tesla of course.]Still 20-25k more than a 2000's simple car though? If he's got super cheap electricity it may start to pencil out, if the battery holds out? I assume a model 3 with 300+k miles isn't going to have a lot of resale value even with a functioning battery?
One of the off brand EV's gets pretty cheap, but they may not make it 120 miles in the cold with an old battery?
I think a Volt isn't a bad option, with cheap electricity you can save some on gas and they are very aerodynamic. I kind of want one but the zero cargo space kills it. They are 5-8K more than the beater option.
