Do the rustproofers work near the exhaust system or do they melt/burn off near there and then rust? The exhaust is low grade stainless but everything around it isnt. How high off the ground do you need the vehicle to spray it? I have an airless sprayer. I plan on powerwashing the undercarriage, the engine bay and the truck bed. Should I bother with the soap spray on the engine to get it looking real nice before spraying grease all on it? Do you wash the undercarriage at the carwash with water on a regular basis or only before reapplication?
From these msds sheets i'm going to assume that the texaco rustproofer is 10% lanolin 20% naptha solvent and 30-40% of both mineral oil and wax. Fluid film contains no solvent and has unknown amounts of both mineral oil and lanolin though probably a higher percentage. If the texaco rustproof was cheaper and lasted as long as the fluid film then i'd use that.
http://www.equivashellmsds.com/getsinglemsds.asp?ID=151548
http://www.chevronmarineproducts.com/docs/RUSTPROOF_COMPOUND_L_EU.pdf
www.fluid-film.com/downloads/nonaerosol_msds.pdf
