This video from the Torque Test Channel might be beneficial in helping you decide.
And here is a continuation on that video...
Based on this, I bought a set of Craftsman Overdrive wrenches. They were quite cheap and seem really nice.
But what happens when he needs the next size up or down unless it's a 10mm because they ALWAYS get used (and lost like the sockets).The OP never mentioned a whole set. He asked for the best open end wrench available.
A single Snap-on wrench in the desired size is not going to break the bank. Hue Haw!![]()
Fair. I call that an advantage at times.The big problem with the Overdrive is they are 6 point box, they require 60° vs the 30° swing arc for 12 point. Not good in tight places.
WrightGrip 2.0.Alright guys, what’s the end all best open end wrench available? I’m tired of mine always slipping with any decent amount of toque.
Currently running a Bostitch set and they are certainly better that the HF ones before…. But there has to be something worthwhile without breaking the bank? Would Tekton be a significant improvement?
True. Years ago, I broke a metric impact socket and they opened a set to replace it. I felt a little bad about them having to do that, but I got over it.If you want a single under warranty they will either open a box in stock and hand it to you ...
My 35 year old Craftsman 10 inch serves me well
I've wondered about this, too. If I have to work an open end so bad it's spreading I'll find a different approachNobody goes and tortures wrenches like they do in those wrench tests so it doesn't mean you will have a failure with "normal" use. I just don't see ANY need for Snap on tools anymore with all the more reasonable priced competition out there.
I have some GW as well and they are decent. The warranty is trash though as you have to do so much to get a tool replaced and takes a long time vs walking in to a HF store for exampleI like all my Gearwrench ones, no issues there.
Stupid question - is a high quality open end wrench practically that much better? Your only holding 2 sides of the bolt?
I almost never use an open end on anything - only when you absolutely must or once loose in very tight quarters?
I haven't had to warranty it, but there's a few places around me that carry GW so I'm guessing I could warranty there.I have some GW as well and they are decent. The warranty is trash though as you have to do so much to get a tool replaced and takes a long time vs walking in to a HF store for example
I feel like the sweet spot is probably that Gear Wrench/Tekton/HF Icon zone.Actually this is a question I wonder also. How much of a difference from my basement line of HF to Bositch to Tekton to, say, snap-on? I'll have to watch that torque channel test and see how much it REALLY matters. Surely there's a sweet spot to buy.
