Best Plastic Trim Coating
Las Vegas NV
Looking to get a semi-permanent ceramic/graphene coating for plastic trim. Not looking for the temporary stuff that washes off easily.
Anyone have any good luck with products or recommendations?
For black plastic, "That Black Stuff" is a black dye that is quite impressive. But the one that I use here in Florida is called "Forever Black bumper and trim Dye Kit (or Cleaner and Reconditioner) (both the same)". It is also a strong black dye, and comes with a foam paint brush for careful smooth application. When used with care, does a great job and lasts for years.
I've seen it at WalMart in the past, but not lately.
NOTE: I've never had the product flake off. But I have not used the 'new and improved' version. There are a small number of people who have had the product peel and flake, about 3% of the reviews.
https://www.amazon.com/Forever-Bumper-Improved-Formula-Larger/dp/B00FAYLPZK
shopping
Have you tried heat gun or torch method? If you are dealing with faded trim.
  • Like
Reactions: Arc
