I'm going to be picking up a 2004 ford ranger here in the next couple days. Wondering what oil you guys would recommend to run? I would like to do 5000 mile oci's at least. So full synthetic would be best but which is best for the fords?
Which engine? The 2.3 and 3.0 aren't picky at all and any conventional 5w-20 will do the trick. You can go spend more and run a synthetic but it won't be any benefit.
The 4.0 can be a bit picky because it has 4 timing chains running around in there.
Originally Posted By: exranger06
Can't answer this question without knowing which engine it has. 2.3 and 3.0 specify 5w20. 4.0 SOHC specifies 5w30 and should absolutely not use 5w20.
Are they not the same block however?
3 different engines - not related
2.3 is a Mazda L series.
3.0 is the Ford Vulcan engine
4.0 is a Ford cologne V6 , modernized with overhead camshafts
Originally Posted By: nwjones18
For an 04 ranger doing a 5k change I'd say you won't be able to tell a bit of difference running any good 5w30 conventional - 10w30...
+1 any conventional oil would easily work for 5k. Personally I would use Pennzoil Conventional or even Motorcraft.
I recommend Valvoline MaxLife Syn Blend 5w30 or Pennzoil High Mileage 5w30 coupled with a Motorcraft filter for a 5,000 mile OCI.
Valvoline MaxLife Full Synthetic 5w30 or Mobil 1 High Mileage 5w30 are also options if you wish to extend the oil change interval to 7.5K-10K. You can run the Motorcraft filters that long also but FRAM Tough Guards & FRAM Ultras are good choices also.
