Patman
Staff member
I've always thought that if you overuse them you could possibly damage the injectors and cause them
to leak after shutdown.
I second the Amsoil PI, Several accounts that use the stuff religously. El Paso Does emissions testing, so the results don't lie.quote:
Originally posted by Spector:
In three cars I keep a bottle of Amsoil PI in the trunk and add one squirt (concentrate) at every tankful. Longest engine on this regemin has 146,000 miles and used since 1000 miles. Never replaced an injector or had a fuel system issue, never had a injector flush etc. All original equip. On a few other cars I use the Techron every once in a while and again, never had a fuel system problem. Do they work, I don't know since all were running well to begin with so not a true test. Would cars have continued problem free without them, who knows.
MMO is used by a lot of Saturn owners to free stuck rings. In some cases, it's poured right into the cylinders and allowed to soak overnight. I haven't done that yet, but from what I've heard, it does work in some cases. I can only assume that MMO has some cleaning properties, albeit as a solvent and not a cleaner. As for the mileage increase, I don't know how it works, but it does. It has also cut my once-constant pinging down to almost nothing. This is what I started using before I tried Auto-RX. It didn't reduce my oil usage at all, but the mileage increase and the elimination of pinging have been appealing to me.quote:
Originally posted by BOBISTHEOILGUY:
I'd argue that MM can increase mileage. It is nothing more than a top end lubricant. That being said, it does nothing for cleaning carbon/soot, it would fail as an octane boost. Can you help explain how MM would increase mileage being that its a lubricant and not a cleaner/ MTBE/ethonal oxygenant?
It comes 12 oz bottles (24 case) 4 -1 gallon jugs case and up. Works great in injected engines! Cleans injectors. Clogged injectors can rob you of as much as 25% of your power and performance. Neutra cleans injectors and restores lost power and fuel economy.quote:
Originally posted by Bror Jace:
I expressed an interest in using Nuetra 131 in some applications around here. I'll probably get some ... but what form does it come in, gallon jugs? Quarts? My car seems to run pretty well ... excellent for a car with 120,000 miles on it but some of the lawn mowers around here could use a little help.
I have used MMO in some vehicles and I've seen it make engines run smoother/quieter and it also reduces oil consumption for as long as it is in the fuel. If removed, oil consumption resumes its previous level.
BUT, I'm reluctant to use this stuff in fuel injected engines. Maybe I'm just a little paranoid about clogging them up.![]()
--- Bror Jace
