Best Electrical Contact Cleaner
KY
I'm cleaning the gauge cluster connection s on a 1999 Wrangler. Suggestions?
Thanks!
It is something that is safe for most plastics. I assume it contains no acetone.
I got curious and looked up the MSDS, first one that came up was from CRC
Not much iso alcohol at all.
Is that methanol? I know nothing about chemicals…
JWC86 - no methanol from what I see. There is isopropyl alcohol (aka isopropanol, or 2-propanol) which is likely a co-solvent as well as a cleaner.
Typical contact cleaners do a very good job of degreasing and moving debris off the application area.
I'm a big fan of Deoxit. It not only cleans decently, but also has some chemistry that de-oxidizes the conductors as well. If you've got some of the "green crustys", this is good stuff!
I'm wondering what the difference is between the CRC red can and the CRC blue can.
I used the red can on the connector that goes to the oil pressure sensor to rinse the oil off. Works good.
I remember I bought this super special magnetic head clear that was recommended by an audio electronics shop. I don't recall the brand name, but it was pricey and came with some warnings. All they said it was was "halogenated hydrocarbons". I suspect that it was just perc (which isn't actually a halogenated hydrocarbon), which is not necessarily the safest thing to use, but whatever it was, it worked spectacularly at cleaning up the head and at cleaning electrical contacts.
Deoxit is expensive. I got a bottle of oleic acid and make my own contact cleaner by mixing 5% oleic acid in mineral spirits. It works quite well in my radio hobby.
Agreed. DeoxIt is very pricey. And it should be used sparingly!
I have use traditional contact cleaner and DeoxIt. I "clean" using the less expensive cleaners; copious amounts to flush away the garbage. Then, only if needed, do I use the DeoxIt, and sparingly; just enough to clean away the oxidation, if present.
Best of both worlds, so to speak.
