And there is another one called JB Weld Plastic Bonder.
I would use a small amount of JB weld and get it together. When it sets, wind a lot of rounds of unwaxed dental floss around it, past the crack. Then put JB weld all around that.
If there's a lot of force on those tabs, I don't think any kind of adhesive will work long term.
Do you get superglue to harden if using globs of it like that? The one or two times I tried it, I felt as if it was not going to harden because I used too much.Cut fiberglass to fit inside the groove, fill the groove with superglue, tweezers to lay the fiberglass into the superglue, then the nose of the superglue bottle to fully saturate the fiberglass. It does not go fully clear but it is obvious when it is fully saturated.
I don't stress the break for many hours, preferably overnight, and if it is still stinky the next day I let it go longer.
I don't think anything is going to work short term either.
atikovi said:If the clip breaks off, I'd just glue it to the body with rtv gasket maker. It will hold it in place but not too strong so you can still remove it easily.
tshephard said:At my house I would 'weld' it with a soldering iron (for positioning)
