Best 2 stroke oil
Echo Red Armor
Husky XP+
Amsoil Sabre
VP Racing
Echo Powerblend Gold
Never use stihl ultra in the silver grey bottles. It is a very outdated 1990's JASO FB (FoxTro - Bravo) rated oil. You want JASO FD (FoxTrot - Delta)
Echo Red Armor
Husky XP+
Amsoil Sabre
VP Racing
Just so everyone is aware, there is no difference in wear protection requirements between FB and FD. The lubricity spec is the same. The difference is that FC and FD require less smoke, more detergentcy and lower carbon buildup.
As mentioned above, EG-D or FD oils are likely the best choice for today's users.
From our two stroke engine testing in the distant past, 32 to 1 is the fuel/oil ratio that provides reduced wear for most users, and for most engines wear rates increase as oil is reduced. In more modern times we've learned that RPM is a factor, as oil migration through the engine is affected by RPM. A 14,000 chainsaw should not be using an 80 to 1 ratio, regardless of oil choice.
A robust EG-D/FD oil I like is Castrol Power 1 racing 2t (the exact same stuff as the superb old TT-S 2t oil)
https://www.amazon.com/Castrol-POWER1-2T-Motorcycle-Oil/dp/B0C813TSXN
So I have been using some Stihl ultra 2 stroke oil in my Stihl 2 strokes. They say the new stuff is some sort of biodegradable veggie oil. Not sure I want oil in my saws that is designed to go bad. What is a good alternative and is the veggie blend ultra any good?.
Never heard of castor oil?
I will add, I have purchased entire truck loads of customer abandonded equipment from a local dealer closing. There were several husqvarna, poulan, and a few el cheapo brand of string trimmers that showed no signs of cylinder or piston wear. Instead the ring was completely carbon seized into the ring land (stuck ring) and while most people would just toss it, I spent the time to clean and break it free. After which all peices ran flawlessly. This is why I personally like modern FD / EG-D oils.
Motul 510/Scooter Expert
Motul 710
Castrol Go!
I like Motul. I run Motul 510/Scooter Expert (synthetic blend) and Motul 710 (full synthetic). Both are JASO FD. A friend of mine is running the 710 in his race karts (that run at over 15K RPM) and is very pleased with it. The only disadvantage is that the 710 doesn't stay in suspension well below 60*F. That is why I use 510 in the winter.
Also, I recently bought some old cases of Castrol Go! 2T (mineral) on Marketplace. It's JASO FB. It says on the back label that is good for lawn equipment too. I think Canadians have it. I heard very good things from loggers about this oil and wanted to try it. Didn't try it yet though.
Motul 710
Castrol Go!
It will work fine. FB has the same lubricity requirements as FD, it's just allowed to make more smoke and can leave more deposits over time
This is my favorite
AMSOIL Saber at 100:1, I have a 25 yr old Kawasaki string trimmer that has been on it ever since it came out and runs great.
nothing beat mobil 1 2t racing 2 stroke back in the day
I still have some. It was a superb all around 2t oil and was said to meet and exceed EG-D specs for lubricity and smoke. But it is good to note there are more robust 2t oils, examples include Motul 800 or Klotz products. The Castrol Power1 2t I mentioned above comes very close to matching the old Mobil 1 product in overall performance.
I wonder if it goes bad? I have a package of 8 100ml bottles (red) still in the shrink wrap from 2003. 3.2 litres makes 32:1.
5 litres makes 50:1. Easy math with the metric system.
Name that movie….. Do you know what they call a quarter pounder with cheese in France? Tell him Vincent.
At one time I ran everything on Lawnboy 32:1 mix nothing died for lack of lub. The smell was the only bad thing, I still have my chainsaw I bought new in the early 80's that did many cords of wood with and trimmed lots stuff, still cuts great even with the original carb. whatever is on sale
Walmart has vp synthetic 2 stroke for a good deal. I tried to buy Royal Purple 2 stroke from Advance Auto parts but their system can't order it.
