Benefits of Conventional over Synthetic
Bio based ester?only ester i think would be awsome would be polyoester (or such)but you would need an oil drier to make sure oil does not get contaminated with water
Bio based esters come from plants, animals, etc. Companies like GET, RLI, etc. use bio based esters.
GET's G-Oil also says it has bio based PAO in addition to esters. I hadn't seen that before.
Those come from the ground too. And the air, and space, but hey
Originally Posted By: badtlc
Not all oils come from the ground. Have we completely forgotten bio based esters?
i found its easier to use regular soap and water to clean up hands that were dirty by regular oil, Pennzoil Conventional or Castrol, compare to syn motor oil. not so for transmission fluid.
Originally Posted By: kschachn
That's not completely accurate, hydrocracked synthetic oil is not "highly refined" nor is it made up from small precursor molecules.
Originally Posted By: Jiblet
Synthesis to a chemist means creating a chemical bond.
In practice it means "growing" a molecule like a carbon chain by adding links to the chain.
If you start with a mixture like crude oil and clean it up (refine it) you end up with what people refer to as dino or mineral oil.
If you start with small precursor molecules and combine them to build up the molecules you want, then that is synthetic oil.
But highly refined oils get to be called "synthetic" for marketing purposes (in USA).
I don't agree entirely with Jib's definition of synthesis. I can assure you that in chemistry, 'synthesis' is not limited to organic carbon compounds or growing those existing hydrocarbon molecules.
Synthesis obviously includes the combination of elements to form new, unique molecules altogether.
This is the big differentiation.
GrI-III oils are specifically derived from crude oil and at no time in their processing are they NOT hydrocarbon molecules. They get sliced, diced and augmented, saturated with hydrogen to stabilize the molecular charge and sequester contaminants, sure, but they're the same hydrocarbons from the crude, just manipulated.
With the F-T process (GTL etc) for practical reasons, the syngas used as feedstock is commonly derived from gas, oil, or coal, those are not nessecary for the F-T process.
One could buy laboratory-grade CO and H derived from any other compound, and with the catalyst still create brand-spanking new synthetic hydrocarbon molecules. The Hydrogen could come from water, hydrochloric acid, anything.
In the case of POE it would be an alcohol and a carboxylic acid in the esterification process, either of which have no dependency on crude oil. The 'true" synthetics are much better representatives of the term "synthetic" IMO and that's why I, and many others, consider F-T oils/POE/PAO to be truly synthetic- from the manner in which they are synthesized.
If I start calling GrIII 'a true synthetics' and believe it, then I'll have to call Parkay Margerine "synthetic" also. And while it just might be, I'd rather not.
So even if the language fails us in not offering distinction between the two types of synthesis, we can still conclude that when it comes to producing a specific petroleum product, the latter methods are far superior at producing a pure, uniform product.
Chemical synthesis is when you perform a chemical reaction to make a product (s). You don't get to choose which chemical reactions get to count as synthesis or not. The problem is people have their beliefs on which forms of oil are the best and then make the definition fit their belief. The problem is the word definition and the marketing definition get mixed together as if they need to have any relationship. The word synthetic when referring to oils is pretty much useless and people should more accurately describe the base oils for what they are - molecular form, group #, etc.
Debating the meaning of the word is a disservice to the oils actual functionality.
Ok!by the sound of the technobable ,it seem some are implying oil corp distil oil!on the water side distilled water was a huge boon to trucking industry .coolant purity was such an issue .cylindr liner were being chewed by the various contaminent and no ,coolant filtration did not help at all .ok it slowed the issue but when expectation of b50 is in the million mile ,solution better come quick because if an american does not fix the issue hyundai wont be shy to bring in a solution .(big rig trailer named hyundai.not one industry is safe,be it textile .truck oil .you name it.if asian find a problem lets say here in oil and they can fix it?who will sell asian or the good old usa?
Most commercial alcohols are made from the petroleum product ethylene (ethene), a gas, which is cheaper than using the fermentation of grain.
ALcohol production is accomplished by using the gas ethylene (ethene) and steam H2O (hydration), represented by the chemical formula: C2H4(g) + H2O(g) - CH3CH2OH, or C2H5OH if used with a phosphoric acid catalyst.
For those who missed this in another thread, here is a History of Synthetic Oils:
Quote:
[Published in the January 2000 issue of Lubricants World magazine]
Synthetic Automotive Engine Oils--A Brief History
by Maurice E. LePera
LePera and Associates
[The story of synthetics development is peppered with war, frigid cold, and variable commercial success.
The synthetic automotive engine oils of today had their start many decades ago, perhaps as early as in the last century. And it seems that since the beginning, the compounds have generated controversy. Some of it has been positive:
Many companies claim to have been the first with such-and-such a development, for instance. And some has been less flattering:
Witness the emergent challenge to even the definition of “synthetic.”
In this article, we examine the history of the compounds traditionally considered to be synthetic lubricants and offer some insights into their former, current, and future role in the automotive engine oil market].
Initial Research and Development in the United States
Although the first “synthetic” hydrocarbons are believed to have been synthesized by C. Friedel and J.M. Crafts in 1877, the first attempt at commercial development of synthetic hydrocarbons did not occur until 1929, by Standard Oil of Indiana. These results were reported later, acknowledging that many gallons of synthetic oil had been made by polymerizing different olefins. However, there was no demand for these new synthetic oils because of their high costs, and this initial attempt failed.
During the same time frame, other types of synthetic oils were also being investigated. One such type, a water-insoluble polyalkylene glycol (PAG), was being developed by Union Carbide and Carbon Corp. H.R. Fife of the Mellon Institute of Industrial Research carried out the original work in the 1930s. Later, these research efforts were augmented by development activities of the Carbide and Carbon Corp. and Linde Air Products Co. It was readily recognized that these synthetic oils, referred to as Ucon LB Lubricants, were inherently more expensive to produce than the best petroleum oils being marketed at that time. Although these synthetic oils possessed special qualities--such as excellent low-temperature fluidity, desirable viscosity-temperature relationships, reduced carbon formation tendencies, and good solvency-- Union Carbide and Carbon Corp. realized that the high production costs could eventually become market barriers for their synthetic oils.
Extensive field tests of these PAG engine oils in fleets of new, older, and commercial vehicles were conducted starting as early as 1942 and continued into the mid-1940s. The results indicated the PAG engine oils performed extremely well. However, one shortcoming of the PAG engine oils revealed during testing was their ability to absorb water (about 3%-4% at room temperature). This water tolerance resulted in a tendency for rusting and corrosion on oil-wetted surfaces when engines were exposed to high humidity.
Some limited testing was conducted in diesel engines, but ring sticking and piston deposits indicated the need for additional research. A number of U.S. Army aircraft operating in Canada and Alaska were lubricated with the PAG engine oils through the summer of 1944 and accumulated more than 150,000 hours with no problems.
The German Contribution
The synthesis of petroleum substitutes from carbon monoxide and hydrogen by means of the Fischer-Tropsch process was commercialized in Germany by 1939. Germany realized early on that supplies of crude oil would become a major problem in operating its war machine during World War II. So the country expended a considerable amount of technical effort to develop its own synthetic fuels and lubricants industry.
From this industry, which was based on coal gasification technology, three processes became commercialized, producing about 10% of the German supply of lubricating oil. One process produced lubricating oils by polymerization of cracked waxes, another by reacting chlorinated Fischer-Tropsch middle oils with naphthalene, and the third by the synthesis and then polymerization of ethylene.
Additionally, Germany was able to produce a synthetic bright stock by the condensation of paraffin with olefins and subsequent ethylene polymerization. Germany also developed special engine oils for operation on the Russian front because of the extremely low prevailing temperatures. These oils were blends of light synthetic oils with adipic acid ester, giving the resultant blended oils very low pour points and high viscosity indexes.
Impact of the Turbine Engine
After the war, development of PAG engine oils continued. National Carbide Company Inc. marketed its first commercial PAG engine oils--Prestone Motor Oil--in two areas in the East during the winter of 1946. The geographical area selected and short duration of marketing were due to limited production capabilities. Concurrently, the New York Power and Light Corp. had been conducting extensive fleet testing using PAG engine oils in a variety of commercial vehicles, tractors, and trucks that eventually accumulated some 605,000 miles without experiencing problems. Because of the limited production capabilities and higher costs, the emergence of the gas turbine engine and its demand for more thermally stable engine oils terminated further consideration of PAG oils for automotive engine applications.
Diester oils (that is, dibasic acid esters) became the focus in the late 1940s and early 1950s, as petroleum-based engine oils were simply inadequate to meet the demands of turbine engines. High- and low-temperature operability, low basestock volatility for controlling oil consumption, and resistance to thermal and oxidative degradation were all prerequisites for these engines.
The turbine-powered aircraft provided the need for synthetic-based engine oils, and the diester oils satisfied this initial requirement.
As the operating temperatures increased with newer and advanced turbine engines, hindered neopentyl or polyol esters came into use; these compounds possessed good thermal and mechanical stability. These synthetic oils had fully demonstrated their superior performance over petroleum-based oils in the aircraft turbine engine. Their demonstrated performance qualities (higher operating temperatures, fluidity at very low temperatures, reduced oil consumption, reduced carbon deposits, etc.) were all viewed as potential technological opportunities that could certainly become benefits for automotive engine oils.
The Emerging Passenger Car Market
As the commercial availability of these diester and polyol ester basestocks had been established for the aircraft turbine engine industry and was growing, oil formulators began to experiment with using these for automotive engine applications. At the same time, production capability was evolving for polyalphaolefins (PAOs), which had actually been synthesized in 1937. Created by polymerizing long-chained olefins, these PAOs were being viewed as possible basestock components for automotive engine oil applications.
Apart from the improved low-temperature starting benefit that would be realized with a synthetic automotive engine oil, other such potential benefits quickly came to the forefront. These benefits included extended drain intervals, increased fuel economy, reduced engine wear, cooler-running engines due to less friction, all-season oil applications, higher operating temperatures, and cleaner engines due to the lower levels of deposit formation. The extended drain interval quality perhaps took on the most importance and provided the key selling point for these oils.
Army’s Experience and Contributions
During the 1960s, the U.S. Army had been experiencing significant problems in operating vehicles and equipment in Alaska in using its MIL-L-10295 Lubricating Oil, Internal Combustion Engine, Sub-Zero (OES). This was a petroleum-based engine oil that produced unsatisfactory performance in a variety of engine systems, particularly in the two-stroke diesel engines manufactured by Detroit Diesel that have sensitivity to lubricant volatility. These engine systems powered a large number of both wheeled and tracked vehicles.
Recognizing the problem to be one related to basestock volatility, the Army initiated a program to develop engine oils for both gasoline- and diesel-fueled ground vehicles and equipment required to operate in cold-temperature environments and year-round. Working closely with industry, the Army subsequently completed engine dynamometer, transmission, and field tests of three types of synthetic-based oils that eventually became qualified and part of a purchase description called “Aberdeen Proving Ground Purchase Description Number 1 (Lubricating Oil, Internal Combustion Engine, Arctic),” issued in 1968. The products qualified under this purchase description included three types of synthetic base products. One qualified product was formulated using an alkylated aromatic oligomer. Another product was qualified using a diester. And the third qualified product was formulated using an olefin oligomer, or PAO. This purchase description was converted to the military specification MIL-L-46167 (Lubricating Oil, Internal Combustion Engine, Arctic) in the early 1970s.
These synthetic oils, which all passed the necessary sequence and component testing initially called out in the purchase description and later the military specification, were quickly “adopted” by the commercial operators in Alaska once the oil was introduced into the military supply system. As a result of later successful field demonstrations at four U.S. Army military installations, use of this class of lubricant spread in the mid-1980s to “outside arctic” use in the northern-tier states and in the higher elevations of the U. S. Because of this, the Army is recognized for leading the introduction of synthetic oils for automotive engine and powertrain applications.
The Push in the ‘70s and ‘80s
The 1970s brought a new momentum to synthetic engine oils for application in both passenger car and commercial vehicles. This may have been due in part to the Arab oil embargo, which resulted in many new synthetic engine oils being introduced. All of these claimed to provide extended drain or “lubrication for life” benefits, and improved fuel economy, clearly brought into focus because of long lines at service stations. Some companies also promoted use of these synthetic oils because of their not being dependent upon crude oil resources. At the same time, the successful application of synthetic engine oils by the U. S. Army in Alaska led to synthetic engine oils being exclusively used during the construction of the Alaskan pipeline system.
The successful penetration of synthetic engine oils was temporarily curtailed as a result of action taken by the automotive industry in the late 1970s. Questioning the quality of synthetic-based engine oils as well as the claims that were being made about them, the automobile manufacturers included statements in their owner’s manuals warning that using synthetic oils would not justify extended drain intervals and that engine warranties could be impacted. Since the extended drain benefit was the largest drawing card for synthetics and served to offset their higher costs, consumer interest in synthetic engine oils declined during the late 1970s.
During this temporary lull in the U.S., Europe began to take the initiative. Oil marketers saw the opportunity to increase their profits by selling synthetic automotive engine oils there, and the European automobile manufacturers pushed the higher performance qualities of synthetics rather than extended drains. This apparently did accelerate the development of the synthetic engine oil market in Europe, which has sustained itself to the present time.
A resurgence of activity in synthetic engine oils has since returned to the U.S. This is in part due to the declining price of synthetic basestocks, the fact that synthetics have gained legitimacy, and the increasing performance requirements for automotive engine oils (e.g., higher engine operating temperatures, increased emission regulations).
Past Problems and Solutions
Many problems confronted synthetic engine oil formulators, ranging from additive package incompatibility to high oil consumption and oil filter deterioration. The additive package problem was perhaps the most troublesome to resolve. Individual additives within an additive package depend upon the composition of the basestock, which affects both solubility and additive responsiveness. Formulators learned early on that additive packages that responded well in petroleum basestocks did not necessarily work as effectively in the different synthetic base oils. PAOs were found to exhibit excellent additive response, but were poor additive solvents. Diesters, on the other hand, were found to vary in additive response but were excellent solvents, except for those additives with which they reacted to form precipitates.
High oil consumption became a real problem with the early PAO-based products, as the formulations caused slight shrinking effects on the engine seals. This in turn caused oil to migrate past the seals; the lower viscosity of these synthetic oils further exacerbated the problem. This was later corrected by incorporating a diester component into the basestock, which provided positive seal swell and improved the additives’ solubility in the base oil.
Oil filter deterioration also initially created problems. Because of the increased solvency of some of the synthetic oils, the adhesives binding the end caps, as well as the phenolic resin treatment on the conventional pleated paper filters, became affected, resulting in filter leakage or bypassing of oil directly to the engine. These problems were subsequently remedied by improving filter construction and going to more efficient depth-type filters.
New Kid on the Block
Although the field of synthetic engine oils had principally been led by the PAOs and to a lesser degree the diester base oils, a new base oil emerging in the mid-1990s began to compete with established market: the very high viscosity index, or hydroisomerized, base oils. Since the introduction of these base oils, there has been much controversy as to whether engine oils formulated with the hydroisomerized base oils can be considered synthetic. In April 1999, a ruling by the National Advertising Division of the Council of Better Business Bureaus allowed engine oils formulated with hydroisomerized base oils to be classified as “synthetic oils.” (See LW’s two-part series, “A Defining Moment for Synthetics,” October and November 1999.)
The Future
Synthetic-based engine oils have continued to grow during the past decade and many expect a continued increase in automotive applications of these products. Almost every oil company now carries a premium-type synthetic-based engine oil in its product line. Moreover, many automobile manufacturers are now specifying synthetic oils for not only engine crankcases, but also transmissions, differentials, and transaxles.
Bibliography
The following sources were used in developing this article:
• Sullivan, F.W., Voorhees, V., Oak, P.T., Barnard, D.P. “The Field for Synthetic Lubricating Oils,”
SAE Paper 310033, May 1931.
• Kratzer, J.C., Green, D.H., Williams, D.B. “New Synthetic Lubricants,” SAE Paper 460215,
January 1946.
• Caines, A., Haycock, R., Automotive Lubricants Reference Book, Society of Automotive Engineers
Inc., 1996.
• Klein, N.L. “German Military Fuels and Lubricants,” SAE Paper 460170, March 1946.
• Wilson, D.K. “Fleet Testing of Synthetic Lubricants,” SAE Paper 480193, April 1947.
• Potter, R.I. “Synthetic Automotive Engine Oils from a Consultant’s Experience,” SAE Paper 760561,
June 1976.
• Lestz, S.J., Bowen, T.C. “Army Experience with Synthetic Oils in Mixed Fleet Arctic Service,” SAE
Paper 750685, June 1975.
• Hopler, P.D., Lestz, S.J. “Application of Synthetic Engine Oils in Army Hydraulic and Power Train
Fluid Systems,” SAE Paper 750828, September 1975.
• Lestz, S.J., Owens, E.C., Bowen, T.C. “Army Arctic Engine Oil Performance in High Ambient
Temperatures,” SAE Paper 892051, September 1989.
• Frame, E.A., Yost, D.M., Bowen, T.C., Villahermosa, L.A. “Development of Improved Arctic
Engine Oil (OEA-30),” SAE Paper 1999-01-1523, May 1999.
• “Pennzoil Technical Product Information--Synthetic Motor Oil History,” URL
http://www.home.aone.net.au/oilandenergy/proddocs/sohistory.htm .
4
• Booser, E.R. CRC Handbook of Lubrication – Theory and Design, Volume II, CRC Press Inc., 1984.
• Bui, K. “A Defining Moment for Synthetics,” Lubricants World, October & November 1999.
• “Chek-Chart Lubrication Recommendations Guide,” Check-Chart Publications, 1998.
A substantial percentage (30-60%) of the reactants used to make POEs for most jet engine oils are derived from coconut oil, castor oil, and/or tallow. The balance are derived from petroleum sources.
Tom NJ
Therefore every single compound to exist in the physical realm is synthetic.
Good work.
Originally Posted By: Miller88
Isn't conventional gear oil preferred for towing?
Not in big trucks. They all use Synthetics with 500,000 mile change intervals.
Good work.
Yes, what's your point? Man made synthetic? It made by a chemical reaction by man.
That taking-over-the-world-thing can be rough!
PS - marketing nerds and their litigation don't get to decide how general they can apply the English word "synthetic" either. That [censored] doesn't fly in any other market than the American one, and the only people to constantly apologize for it are the ones trying to avoid coming to terms with the fact that they have been had. No one wants to admit it, therefore we have people arguing the case FOR those who have deceived them. GrIII is the cheapest 'synthetic' to produce. Slapping the term synthetic on the highly refined crude (cracking is a form of refinement) just SUGGESTS (suggestion, the most powerful tool of marketing) that POE, PAO and GrIII are ALL EQUIVALENT in virtually every way; including cost to produce (yeh, the retail prices also suggest that in a much realer way), therefore instilling a FALSE SENSE OF VALUE into the consumers' minds. THAT IS CHICANERY. PERIOD. Multiple wrongs don't make a right.
No matter what anyone says, crude oil derived Gr1-3 MUST BE DERIVED FROM HYDROCARBON CHAINS THAT ALREADY EXISTED IN THE GROUND. Period. Other synthetic base stocks do NOT REQUIRE CRUDE OIL AT ALL for their synthesis. The fact that some of it does derive from crude and/or organic gasses, is simply a matter of economics, NOT CHEMISTRY.
Great tirade, but how does that relate to performance? You are correct that the reason ExxonMobil went to severe hydrocracking from a majority PAO based oil was cost, but they have shown that the performance is nearly identical (and superior in some aspects).
All this flapping about regarding severely hydrocracked synthetic oil just because it isn't made like PAO was made is almost pointless IRT actual performance of the finished product.
And your last paragraph - my response (and this is a serious, not snarky question) would be- so what?
And given PAO supplies, I don't think many of us would want to use synthetics (at least pay for them) if every Group III synthetic on the market suddenly started having primarily Group IV base stocks.
jrustles: It's not just America. It's Canada, too, and many other places. Germany has labeling laws, but what did that accomplish? Oil companies invent new words, and German cars call for specifications, anyhow.
Today's conventionals aren't "better" but for the average car, they are all that is needed. Unless you want to go 7500+ miles between oil changes, you race your car, have a turbo or DI, or live in sub zero temps, or have a car that strictly requires it, synthetic can be a waste of money. They most certainly have their place, but that place isn't under the hood of every car in America.
You have any hard data to back this claim up because I'd love to see it and by this I don't mean used oil analysis as in my book they dont mean much. I am looking for tear downs and micrometer measurements of engines using Mobil 1 oils when the were PAO and when they were not. Heck I have even followed the used oil analysis of Mobil 1 before and after using Gp III synthetics and in many used oil analysis the iron numbers have gone up after they changed to Group III. But I am really interested in your evidence of tear downs. Thanks.
