Vehicle: 2006 BMW K1200LT
Oil: BelRay EXL 20w50 API SG
Oil Filter: stock BMW
Oil added: none
Additives: none
Total mileage: 10977 Km/6860 miles
Mileage on oil and filter: 8777 Km/5485 miles
Analyzed by: Wear Check Canada
Sample Date 05/15/06 06/19/06 Current
Time on Unit 896 3095 10977 kms 6860 miles
Time on Oil 896 2200 8777 kms 5485 miles
Time on Fltr 896 2200 8777 kms
Oil Maint. changed changed changed ---
Filter Maint. changed changed changed ---
Silicon 33 10 9.1
Potassium 0.7 0.3 0.6
Sodium 2.4 0.1 204
Fuel % <2.0 <2.0 <2.0
Glycol --- --- NEG
Water % <0.1 <0.1 <0.1
Soot % --- 0 0
Sulfation 29 10 11
Nitration 15 6 7
Boron 4.7 1.0 0.7
Barium 0.5 0.1 0.1
Calcium 1383 1643 716
Magnesium 5.4 6.2 515
Molybdenum 4.9 44 5.0
Sodium 2.4 0.1 204
Phosphorus 841 1337 1088
Sulfur 3297 6039 8006
Zinc 926 1360 1180
[email protected]°C --- --- ---
[email protected]°C 7.9 13.7 13.7
Oxidation 8 9 11
TAN 1.30 2.45 2.12
TBN --- 4.52 3.71
Iron 12 8.4 22
Nickel 3.2 0.9 2.9
Chromium 0.2 0.3 0.4
Titanium 0.1 0.1 0.1
Copper 7.3 8.2 18
Aluminum 6.6 7.5 4.3
Tin 1.3 0.8 2.5
Lead 2.9 1.9 5.1
Silver 0.0 0.1 0.0
Comments: These results are for a 2006 BMW K1200LT motorcycle. This is the 3rd oil change on this unit. Previous results show very low levels of sodium.
Wear Check Recommendation: Test for glycol is negative. Water treatment chemicals present, indicating slow coolant leak.
We recommend that you drain the oil from the component if this has not already been done. We recommend an early resample to confirm this situation, however, a minimum of 10 hours, 500 miles or 800 kilometers on the oil is required before resampling to prevent false positive glycol reactions that can be experienced with new oil. Check for low coolant level.
Question: Does the Wear Check conclusion of a small coolant leak seem reasonable?
