theres no free lunch. I have the noco 10, and dabbled in renewable energy years ago, was even published at one point in home power magazine. Once a LA battery is worn, aged, sulfated, there arent many easy things you can do to bring them back. The noco has a conservative charge strategy… it may be fine with newer batteries, but it’s kind of hindered with aging batteries with an increasing internal resistance. It’s good that the noco has the “fix it” function, but its a bit of a mixed bag.
the “fix it” function basically pushes a higher voltage charge in sweeps. It’s kinda similar to just leaving an old school charger operating for longer than you normally would - into light bubbling for some softening of sulfation, equalization charging. My issue with it, is that its slightly too aggressive for a healthy maintenance charge on a good battery, and “too much too late” for a battery that’s too far gone to be gentle with. If you’ve got to blast 15+ volts into a tired battery for it to charge, it’s not got much left to give.
I’ve tried the “fix it” function on a couple of batteries. For a “mostly dead” battery, it just puked fluid all over the floor, and the battery still failed to start the car. On a mid-life AGM, the starter spun quicker for the first start and it did perk it up a bit, but I’m not sure of the consequences it might have done by over-volting the agm. I’m not sure I trust the algorithm.
you can probably tell I’m not thrilled with the noco. Where it‘s good - it is a conservative and gentle charger. On the vehicle AGMs it settles to a very low current (200 mAh or so) charge, gently, gently, slowly, bringing up to 14.4V or so, the shuts down until 12.6 or so, then turns back on to the slow slow rate. So it won’t rapidly recondition the battery, but a deep cycle sitting on it for 3 winter months will probably be delighted. It would be better if it would simply float to a set voltage, slightly different for each battery chemistry. Setting it on power supply mode of 13.8 might actually be the best method after the charging algorithm is done.
