How are you taking voltage readings? What you have described make no sense if you are using a Digital Multi Meter and measuring at the battery terminals.
If you are relying on a dash gauge panel voltmeter then okay. I Am not familiar with your vehicle but I could see how a missing ground strap might give the readings you've indicated here.
Have you ever put that battery on a regular charger?
Harbor freight sells a DMM, sometimes on special for $2.99. It is surprisingly accurate and a great help when dealing with electrical issues
