its important to have good connections, BUT the alternator itself measures voltage at the alternator, so the charging system should operate at a steady voltage no matter what the battery is doing.. does the vehicle have an external voltage regulator or is the voltage regulator built into the alternator? One other thing was as I said previously, are you sure the belt and tensioner are doing their job.I also noticed both battery connectors ground out when tightening them, as in they only grab the terminals so much before they won't tighten anymore. I can rotate them both by hand, but I have to push really hard.
