About two weeks ago the battery (the alternator, I pulled that and replaced it w/a Borg Warner; two days later, battery is again dead.
At first I thought I had a parasitic drain somewhere, but before pulling fuses to go that route, I decided to check the voltage at the battery while the car is running (duh - something I should have done far earlier). Anyway, after charging the battery it reads ~12.43v; w/the car running, it reads ~12.33v. Now I'm no wizard w/electrical (and pretty amateur w/a multimeter), but shouldn't the battery be showing north of 14v when the car is running? And if that's the case, it would appear that the car is not charging the battery under load.
Any tips on where I should start looking? I'm worried that I have two separate issues: The charging system isn't working and I have a parasitic draw. If I can't flush this out soon, I'm going to have to take it to a garage...and I wince at the cost of doing an electrical diagnostic.
Thanks for any help.
M_C
M_C
