I don't consider myself a n00b when it comes to most things automotive, but this is really stumping me.
New battery in my wife's Saab, cleaned the terminals and put anti-corrosion gel and the treated felt pads on there. Within a month, they are all fuzzed up. Baking Soda to neutralize, cleaned, and reinstalled. Same deal. Had the car at the tinting place today, and they said the (new) battery died so they had to jump it and re-clean the terminals. The car is hard to start (typical Saab), but voltage at rest and running is in acceptable ranges.
EDIT-- when I say fuzzed up, not just a little bit...picture a terminal in your had, and the rest of your fist is acidic corrosion...it's A LOT!!!
My Subaru is also getting corrosion (but not nearly to the extent of the Saab), which is making me think it may be an environmental issue (moisture/humidity?), but thinking back I may have recalled that excessive corrosion with a degrading (but new) battery may be pointing to a bad ground or grounds, or systems that remain "on" when the car is off.
Any thoughts on this?
