- Joined
- Jan 12, 2025
- Messages
- 62
Mine would do constant current charging only briefly and then would go into a pulse mode. The technical description of how this device works is mostly lacking, and there is no mode indicator, but it could be that it was improperly entering the desulfating mode, which pulses. The thing is, it did that on every battery, including ones which were practically brand new. So perhaps it was defective from the get go, trying to desulfate batteries that didn't need that. Or maybe that was normal operating procedure for some models.Hmm... I used a DC amp clamp on my HF 4 amp charger to see how it's algorithm worked. On mine, I regularly saw it put out a nominal 4 amps on regular sized car batteries (groups 65, 34, 24, etc.). It would do the "probe mode" thing you mentioned and then did a series of constant current charges. It would put out 4 amps and hold it steady until the voltage climbed to about ~14.4v to 14.6v, then it would start over with a probe and then charge at 2 amps until the voltage climbed back to fourteen and a half volts. It would repeat the process with 1 amp and finish with .5 amps. With regular flooded batteries, the float charge would bounce around between 13.2v and 13.4v.
I wonder how many different variations of this charger HF has sold. They all look the same from the outside, but they may not be the same inside. Mine is at least 4 years old, is yours recent? There are no date codes or production numbers on the outside of the device.
