I'm going to be that guy. There are significant method issues you are not taking into account.
1. temperature-there is ZERO need to take temperature into account when all of my above tests were taken at nearly the exact same time of day at nearly exact same ambient temps, with the battery resting for the same exact 12 hours. When necessary to take other factors such as ambient and actual battery temps into account, I have a BT608 tester that reads temp directly at the clamp.
2. tester technology- I am fully aware of the limitations of the tester technology. These types of testers are just meant for a quick health check, not a scientific deconstruction, elemental analysis and reconstruction of the battery.
3. parasitic load from vehicle-here again I am 100% aware of this, which is why I took all the measurements while the battery was connected to the vehicle each time, to limit variables. There is nothing abnormal or wrong with the charging system on my car. If there was a problem with the system, then I would disconnect the battery and check it that way. Just to be sure.
Considering these one at a time.-
Lead acid batteries are temperature dependent devices, and so are their measured electrical properties. For two tests of the same battery to be comparable they must be made at the same temperature, ideally in a temperature controlled chamber, but more practically, at "close" to some target temperature. Like 25C +- 1C. Minimally, note and report the temperatures during the test.
The small electronic testers don't actually measure the R and CCA, they do some tests and use a formula to derive them. They are OK for detecting a really bad battery with terrible R, but not so good for comparing the same battery in slightly different states of charge. A more accurate, but vastly more time consuming approach, is to use a device like a DTL150 to discharge the battery at C/20 and plot I and V over time (as in many of the posts in this thread). Ideally this would be down to a full discharge, but that is bad for the battery. An alternative is to do all comparisons by discharging for a known time (2 hours) or to a target voltage (like 12.4V, maybe 12.0V, not lower). Do all your tests the same way and you can compare them. Except... this is problematic because these tests take hours and the temperature will change during the test. Without having a temperature controlled place to do this the battery is changing its properties during the test.
Trying to measure a battery that is attached to a car is a mistake. It is fine to see if it is "Good" or "Bad", but it isn't OK for making precise measurements of battery properties. Merely walking near the vehicle with a key fob in your pocket can cause the car to change the amount of current it is drawing from the battery. On our Prius "testing the battery" from the front jump point gives different values than testing on the posts with the battery detached from the car. That is an AGM battery, and it would fail the former and pass the latter. (And it was a nearly worthless test because the little testers are not at all precise when used on AGM batteries.)- There is no "mistake" here, as noted above, this was intentional. Unless there is something wrong with a quick test result on the little Ancel, there is zero need to disconnect the battery for my test. When doing a quick health test on a cars battery/charging system, there is no need to disconnect a battery, unless faults are strongly suspected. Any good professional tech/ mechanic would indeed start battery/charging system diagnostics with the battery still connected. Like with my Autel BT608 battery tester, with amp clamp attached, a tech would check the battery health, followed by the starting, charging health, terminal connections and/or corrosion et al. If no problems were found from diagnostics, it would be a complete waste of time to disconnect the battery.
We live in a hot environment, and water loss is the primary killer of batteries here. Many batteries these days cannot be serviced. Is a battery drying out? Electrical tests will hint at that, weighing the battery will answer the question. So I also suggest weighing a battery periodically. Each time use the same accurate digital scale and put the scale in the same place (on a spot of the floor, position on a table,) because tilt could be an issue if the scale is in a different place. Weigh it when it is brand new, and then once a year or so, pull it out, clean it off thoroughly, dry the outside, and weigh it again. The difference will be the amount of water lost from the battery (mostly, maybe a little acid will also have escaped). - Did I say somewhere that I don't know anything about cars or batteries? You do not know my experience or knowledge anymore than I know yours.
